pics of fuel system setup underhood
Old May 9, 2010 | 05:28 PM
JASON 77's Avatar
Default pics of fuel system setup underhood
lookin at what everyone is doin for fuel rails and regulators. what kind of regulator r u runnin? where did u mount it.
this is for a T70 truck mani build if needed to know. thanks
Old May 9, 2010 | 06:30 PM
tomz28's Avatar
hear are some for you buddy
dont mine the mess the engine was being installed, in these pics
Old May 10, 2010 | 04:03 PM
91sbcamaro's Avatar
^^ Where did you locate your alternator to?
Old May 10, 2010 | 07:10 PM
JASON 77's Avatar
what to do bout a return line?
Old May 10, 2010 | 07:58 PM
brianfromhawaii's Avatar
some people use evap
Old May 10, 2010 | 08:07 PM
blazin's Avatar
Mount the regulator on the return side of the rail.
Old May 10, 2010 | 08:20 PM
JASON 77's Avatar
Any pics would b great. I have the fittings to connect to the evap line, what do u need to do at the tank to make this work? Also how is everyone running there lines from the car to fpr to rails and then the return?
Old May 10, 2010 | 09:48 PM
blk00ss's Avatar
Heres mine.
Old May 11, 2010 | 03:03 AM
tomz28's Avatar
i use the stock feed line as my return. the FPR sit right on top of the line. there are 2 walbro 340 pumps in the tank. the both have -6an lines that go into bulkhead fittings at the top of the sending unit. then a Y-block ties them together and -8an all the way to the back of the left fuel rail (when looking at the engine).
i hope this helps
Old May 12, 2010 | 09:56 AM
Nasty N8's Avatar
Leave the EVAP line intact it is a very good vent system for your tank. Give me a call I can help you spec a system for your needs.
