Fuel system and computer for turbo 5.3 in a s10?
I am getting ready to do a 5.3 with a mp t70 in my 89 s10. My goal is 500hp to the tires on PG with room to grow eventually.
My first question is, what computer and wiring harness should i use? Keep in mind the i will be running a th350 trans so i dont need the computer to controll it.
And the secoind question is, what fuel system( pump regulator and lines) should i use? I would also like to used the stock gas tank too which will be upgraded to the stock 20 gal tank.
Im thinkin the aeromotive a1000 fuel system with -8 feed line and -6 return, but that just me thinkin
Any help from you guys would be a big help!!!
If you can get a single Walbro installed in the tank that would be plenty for your 500rwhp goal. I have a retro swap line kit to make an easy fuel system for older cars. Give me a call I can help yu out with your system.
And what stock ECM and wiring harness and tuning software is the best to use for what im going to be doing?
