-8 an feed line fitting
Kleeborp the Moderator™
Are you talking about the quick disconnect fittings (like the ones on top of the fuel tank, going in to the fuel filter, and in to the stock fuel rails)?
Aeromotive part # 15118 (AN quick connect adapter fitting)
Aeromotive part # 15607 (-8 ORB to -8AN adapter)
You'll need both parts for it to work...the quick connect adapter has female threads cut for an o-ring boss fitting, so the second part turns that into a male -8AN.
