2:1 Boost Reference Regulators?
Also, this is probably a dumb question, but would the pressure remain essentially at the static pressure until boost kicks in (pressure above atmospheric) or will anything above full vacuum start to make it rise? I believe it is only for boost, but want to be sure.
FMU's or high rising rate regulators are generally to make up for too small of an injector.
If you want a properly engineered system for your application, feel free to give me a call.
I'd prefer to use 60# ones since they idle well, but without huge pressure numbers, they might not make the power.
I'm doing a pump gas 408, turbocharged at 15psi. 1000hp might be optimistic.
Yes you guys did a wonderful job. LOL you should see the stares the car gets down here. Dont worry ill have some thing for you to tune again. just have to finish picking the design and parts im going to go with and get a little more time to work on it .
With a 1.1 FPR the injector will flow the amount of fuel of the injector is rated at the base presssure. so yes the it stay a constant flow rate. Im going to round here. 96lb at 60 psi base will flow 96lb 96lb injectors will 10 psi of boost in intake will flow 96lbs with a fuel psi of 70.
So using a 1:1 BRFPR as you sit at idle, the flow is maximized since you re at base fuel pressure and the engine is at vacuum. Then as you open the throttle, fuel rate goes down because the base fuel pressure stays the same, but manifold pressure increases. Then when you are actually at boost, the fuel rate begins to stay constant....right?
