just converted to E-85!!!!!!
Old Jul 9, 2010 | 01:20 AM
tyler ovel's Avatar
Default just converted to E-85!!!!!!
k well i just converted my car to e-85 like a week ago and am liking it so far! car runs smoother than ****. haven t done the wide open throttle tune yet because im running three tanks thru just to make sure that most of the varnish is out of the system. Im on my third tank and just changed the fuel filter so we'll see what she dynoes with the e-85, was 394rwhp. Will keep you posted on my resoults.
Old Jul 23, 2010 | 12:51 AM
tyler ovel's Avatar
ok now here is a little up date on the e-85 conversion. I havent done the wide open throttle tune yet but hope to next week. Car runs so smooth on the base tune. Sarts up a little slower than on gas but gas dose burn hotter so explains that.
Idle's like a champ, and even smells like corn haha. I can feel how the car likes to get up and go a little bit more but havent takin it up high on the rpms cause there is no wide open throttle tune.
Oh yea i forgot to mention all i did for this convertion was change my pump out to a 255lph and put in bigger injectors and had my shop do a base tune . I guess im being some what of a test dummie to see if i do or do not need to change out my rubber fuel lines. I here on here that some have run without changing the lines and some swear that you need to change out the lines, rails, pump, injectors and some ohter stuff. I guess i will wait and see hahaha
Well hopefully i will have the dynoe result in a couple of days, not expecting much since i dont have really high compression but we'll see. Thanks for reading
Old Jul 23, 2010 | 02:03 AM
MECHAM's Avatar
hmmm...unless your tune was crappy before. i would expect you to make a lil over 400.
very interested in seeing the results
Old Jul 25, 2010 | 11:28 AM
fatboyzcamaro's Avatar
just what im looking for.
results please.
Old Jul 27, 2010 | 03:02 AM
tyler ovel's Avatar
ok well the results are in and its not bad but would have liked more. Before i convertited to e85 i dynoed 394rwhp in 66 degree day.
When i convertited to e85 the shop only changed my fuel injectors and mad adjustments to my tune so it was drive able. i drove the car for three tanks to get most the varnish out, changed the fuel filter and took the car in today for the wide open throttle tune. Results again where 394rwhp in 85 degree weather.
Now i wasn't there and havent picked the car up or talked indepth to my tuner so i dont have the full specs., but from what he told me over the phone my first pass was 376 rwhp, and then after all passes he got it out to 394rwhp again. The only thing that he could think of for the reason power loss was do to the hotter temp.
So if that is all true, then technially if i gained 18 rwhp at 85 degree weather then it should be the same at 66 degree weather, right? So at 66 degrees, technially i'm 412rwhp? I dont know if this is how the temp and horse power loss or gain works but its my thought.
Well i will pick her up tomorrow and let you know the full specs.
Let me know what you guys think! thanks
Old Jul 27, 2010 | 09:26 PM
tyler ovel's Avatar
ok well i picked her up today and spoke with my tuner and we figured out where my power loss was.
First off i changed out my clutch to a monster level 3 with a steel flywheel form a RPS clutch with an aluminum fly wheel. Plus the monster is a 12'' pressure plate and the RPS was an 11'', so there is more wieght on my crank witch in return will not spin as fast wich results in lower hp. maybe 5-8 im thinking.
Next the weather. it was 66 degrees in november when i first tuned it. Yesterday it was 85 degrees when the car was tuned. im guessing maybe 5-10 hp was lost there but i could be wrong, i dont know
Well any hoo, the car rips harder than before!!! taking it to the track on friday, so we''ll see what she dose. Will keep you posted for those who care!
Old Jul 29, 2010 | 03:39 PM
RedVertTA's Avatar
Subscribed.
Old Jul 29, 2010 | 04:17 PM
thatguy383's Avatar
sweet. i wan to run e-85 in all my vehicles so this is encouragement
Old Aug 3, 2010 | 08:31 PM
ls6427blown's Avatar
i want to run e-85 too guys
