Heres a easy one for you guys....
What is this? At first I thought it was a inline fuel pump then I got a closer look and I cant find a fuel line going into it from the gas tank. Its has 2 lines going up to the motor...is it something with the return line??
That is the ATI Procharger inline pump unit that came with the old Procharger kits. I believe it is a 190 gph pump. Someone correct me if I wrong. If it is still being used you will have one side hooked up from the tank and the other should be routed to through the fuel filter. I would need to see where the two lines are hooked up to have an idea of what it is doing. Do you still have an FMU on that car?
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
im not going passed 450 until the motor is built, and thats going to be a few years so if the pump I already have will support the 450, i'll just stick with it and get some 42# injectors & a alchly meth kit.
Bob from brute speed told me the inline pump that comes with the base P1SC kit will support 550rwhp...and I only want 450ish since I have a stock motor.
