210lb high impedance injectors in stock
want to make some serious HP on E-85?
check out these
http://fuelinjectorconnection.com/sh...&productId=242
check out these
With your improved spray pattern and pulse width I would be curious how they would tune on a street car. That would be WAY plenty of injector for what I am doing. Are these meant to hold up to some street driving? My car generally has seen 3-5k miles per year. The only thing that concerned me are the fact they have very low pulse width and I assume very fast action.
and then having a FPR so as MAP changes you end up getting your desired settings.
i just got in 160lb high impedance ls1 injectors. (they drop in a ls1.. same length and plug) I know these would be easier to tune than the low 120's due to the low pulse rate that these can operate. I also have the injector data on these and the EFI live files needed to get them to work in a N/A or Boosted engine. They are a little pricey at 145 each, but we are offering them with a money back guaranty, who would like to try them?
LABELS Minimum Injector Pulse Width (Milliseconds) LABELS Minimum Injector Pulse Width (Milliseconds)
RPM {link: SAE.RPM} Value RPM {link: SAE.RPM} Value
0 0.000000 0 0.000000
512 0.875000 400 0.875000
1024 0.875000 800 0.875000
1536 0.968750 1200 0.904583
2048 1.085938 1600 0.981690
2560 1.234375 2000 1.073624
3072 1.304688 2400 1.196381
3584 1.351563 2800 1.270253
4096 1.351563 3200 1.320801
4608 1.351563 3600 1.351563
5120 1.351563 4000 1.351563
5632 1.351563 4400 1.351563
6144 1.351563 4800 1.351563
6656 1.351563 5200 1.351563
7168 1.351563 5600 1.351563
7680 1.351563 6000 1.351563
8192 1.351563 6400 1.351563
6800 1.351563
7200 1.351563
7600 1.351563
8000 1.351563
