where can i find the part numbers for fuel injectors?
I have two sets of fuel injectors for my trans am(ls2 block)and i want to look up the part numbers to find out what they are and the flow rate. Where can i find them? Thanks,mike.
The one is short with a blue seal on one and a red one on the other. it has alot of numbers on it. 341 in big numbers 0280158051 and 1257634 and 112308. the silver bottom has 80526 and under that is 06914305. tha long white one has #24508208. Thanks. mike.
the 0280158051 is a stock ls3 injector. It is 42lb at 58psi, It has a us car plug and is 38mm o ring to o ring. The Bottom orange o ring will not fit in a ls1 or ls6 manifold. The white 24508208 is a stock GTP 36lb at 43.5.. it is a drop in for a ls1 or ls6 and has a minitimer (ev1) plug
