How do you test the aeromotive FPR
you can use a vac/preasure pump, hook it up tothe vac port on the regulator start the car, start adding pressure and watch the fuel pressure should go up 1:1 ilb of boost or pressure should = 1 lb of fuel pressure. I also did this to fine tune my meth kit worked great.
