Fuel Level Sending unit for 2002 Firebird.
Old Nov 17, 2010 | 05:55 PM
Need4Camaro's Avatar
Default Fuel Level Sending unit for 2002 Firebird.
My fuel gauge has stopped working and Im positive its the sending unit. Where can I get a fuel level sending unit? Delphi says they're now obsolete and the Autoparts stores are saying you have to buy a whole new fuel pump assembly... thats $400 and I wanted to upgrade to a Racetronix Pump for an upcoming motor swap...
So my question is
#1 - Can I buy the sending unit seperately? and if so from where?
#2 - If I can't, does the Racetronix Fuel pump come with its own sending unit for the fuel gauge?
#3 - If the above two don't work... can I buy an LS1 Fuel Pump assembly and get the gauge working and build my V8 to 400 HP on a stock LS1 pump?
Old Nov 17, 2010 | 06:18 PM
NBM-LS1's Avatar
The stock pump will handle 400hp.
Old Nov 17, 2010 | 07:23 PM
O2Form's Avatar
http://cgi.ebay.com/ebaymotors/NEW-F...item5d2c32f6af this should work
Old Nov 17, 2010 | 10:21 PM
Originally Posted by O2Form
You rock, will that work in a V6 car with a racetronix pump?
Old Nov 17, 2010 | 10:46 PM
O2Form's Avatar
http://cgi.ebay.com/ebaymotors/New-F...item53e43b91b5 this is for v6 but i'm 80% sure they are the same part.
Old Nov 17, 2010 | 10:57 PM
On the compatibility it said it wasnt for the V6 Models for both of those links - which is why I was wondering
Old Nov 17, 2010 | 11:05 PM
O2Form's Avatar
yeah i seen that but i'm pretty sure they are the same. Sorry if i can dig up more info i'll post it.
Old Nov 17, 2010 | 11:09 PM
O2Form's Avatar
http://www.rockauto.com/catalog/x,ca...parttype,10729 rock auto has it but like i said i'm sure you can use the v8 sender.
Old Nov 17, 2010 | 11:26 PM
cool, I'll go with the V8 sender as its much cheaper... As far as reusing my floater... just making sure that this wont be an issue cuzz my old sending unit doesnt work...
Old Nov 18, 2010 | 02:58 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
