ls1 fuel problem again
1. the cars trans went out sometime around when the problem started so could something electronic in the trans keep the car from getting fuel and starting?
2. the car also has a new battery but ive noticed the battery gauge is low sometimes so could it possibly not be getting enough cranking amps to start?
3. could the fuel regulator on the pump assembly be bad?
4. car is using the bcm and key from the 2000 model could it be different from the 02 model? the 2000 was just about the lowest of the low when it came to options no power anything but the 02 had just about every option
any other ideas would be much appreciated.
1. Are you using all the V8 lines & sender?
2. Did you put a fuel pressure gauge on the rail to check the pressure?
Provide more data to determine if it is truely fuel related...
If you swapped all the components, you should be OK. Verify pressure to prove the car has enough pressure to sart, then go on to other things.
CJSTALLINGS, the V6 had a engine mounted regulator & different fuel lines. To add a V8 you would need to add a regulator up front, connected to the V6 return line to control the fuel pressure or swap over to the V8 lines & fuel system.
