fuel return line in top of tank...pipe inside or not?
planning out my fuel system in my regal and had a quick question about the fuel return line. im gonna drill a small hole and put a -6 bulkhead fitting in the top of the tank. my question is do i need to have a pipe hooke up to this fitting on the inside of the tank or can i have it just return right into the tank with no worries or airation(sp) or causing any other problems. i never race the car on anything less then 3/4 of a tank so i would not think this would be a problem but i have been reading where people are stating you should have a line in the tank to avoid any problems. curious if any pipes bolt to a bulkhead fitting? should i just throw a 90degree fitting on the inside of tank on the other side of bulkhead and have it hit the side of tank before splashing into tank? thanks guys
