mototron 60#ers are the shizzle!
these got ran successfully to 775 rear wheel & 840 tq today at a fuel pressure of 76psi. these will work just fine with the stock computer (high impedance)
also in my fuel system:
speed inc billet rails and BIG filter
cas rising rate regulator
twin in tank walbro gss340 pumps
russel-8 single feed line
stock pressure line used as the return
i was absolutely SURE i'd have to move to 83's etc. but fwiw these babies are about maxed
but talk about impressive! im glad i got my set when they were 430 a set.
dyno graphs in homepage link.
but talk about impressive! im glad i got my set when they were 430 a set.dyno graphs in homepage link.
Were these easy to tune, I'm pretty sure these will support the goals I'm looking for, now the ? is......
These or the 57# Siemens, the Siemens have the benefit of being flow matched.......
I got a 420LPH pump, CAS regulator, Speed Inc. rails, etc, all braided lines......its ready to go on that side......
i dunno how far those seimans have gone before?
i really dont notice mine not being flow matched
if you are looking under 800 i am pretty sure too.
they were easy as pie to set up with edit on my car (before the switch to dfi).. i posted my flowrate and fuel pressure here before for my tune w/ stock offset
and i didnt hear anything at all about difficulty with dfi, i dont imagine there was any at all.
something like 80% at the fuel pressure i'm running.. so they can do more, but 80% is the rule of thumb for most you want to run the injector.. which lots of people go over without problem.
good luck with your combo dude.
