Is my fuel system adequate?
Old Jan 24, 2011 | 06:18 PM
pHEnomIC's Avatar
Default Is my fuel system adequate?
I have the racetronix kit with wire on my 02 trans am.
So far I have 46lb green tops, ls2 fuel rail, on my 404 ls2 making 530-550 rwhp.
I also plan on using a wet kit, 100-200 shot.
I know I am fine with n/a needs, however I am worried that nitrous may require more volume than my system can provide.
Any input?
I also pondered about setting up a fuel return system like the c5 vettes do, would this do anything for me or is it a waste of time/money?
Old Jan 24, 2011 | 09:16 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You should have a bigger fuel system for safe operation at this power level.
A return style system is preferrable for stable fuel pressure control.
Give me a call & I'll be glad to go over the details with you.
Old Feb 3, 2011 | 09:29 PM
pHEnomIC's Avatar
Ill give you a call one of these days, anyone else have other input?
Old Feb 4, 2011 | 02:06 AM
LS2Ttype's Avatar
run a kenny bell boost a pump with a full open throttle switch, when you NO2 comes on the kenny bell will send 18 volts to your fuel pump and keep your fuel pressure up, i have one for sale, i also used this set up for years, i was running a 150 shot but could have went with a 200 if i wanted to ,
Old Feb 4, 2011 | 11:02 AM
armyboyatc's Avatar
I wouldnt run that on stock rails. I would either upgrade the fuel system with rails, return and regulator or get a stand alone fuel system for the nitrous. Just my .02
Old Feb 4, 2011 | 11:19 AM
pHEnomIC's Avatar
Is my current system adequate for the 404 w/ h/c/i without nitrous?, should be around 550 rwhp.
Old Feb 4, 2011 | 11:33 AM
LS2Ttype's Avatar
the kennybell acts as a stand alone system it will only send extra voltage to the fuel pump when your nitrous system is on and your hit 90% throttle, the throttle switch will ground the connection and turn on the kenny belll just like it activates your nitrous and fuel seloniods, worked Perfect for me
Old Feb 4, 2011 | 11:41 AM
pHEnomIC's Avatar
I know that the kb would provide enough pressure, but ive heard that there is a difference between pressure and flow, and sometimes doing radical changes in pressure can cause terrible effects on flow. That's kinda why i wanted to do the return in the first place as it gives a flow reservoir.
Old Feb 7, 2011 | 12:16 AM
01ssreda4's Avatar
How long will a stock pump last at 18 volts though........
