Surge tank mounted FPR question
I need to step up my fuel system and want to avoid the "can't get on it with less than a 1/4 tank" issues that plague the long, narrow stock GM truck fuel tanks bottomless dual-pump buckets. I have a 3l aluminum surge tank that I'm going to use to feed a pair of dual external Bosch 044's. It will be fed by my intank Walbro 255l. I'll be mounting the surge tank with the Bosch's attached under my truck bed. For the time being, I'll be using a stock fuel rail.
I'm been debating mounting my Aeromotive A1000-6 FPR on the surge tank to make a nice, compact assembly. I'd be using a -6AN return line from the rail (minus the the stock fpr) but instead of having the FPR at the rail, it would be at the surge tank end. It will be boost referenced so I'll also be running a vacuum line back to the FPR.
My question is will there be any issues with fuel pressure instability having the FPR 15' +/- from the rail. The truck will be tuned for the new fuel system so I'm hoping any irregularities can be compensated in the tune.
I was just looking for a cleaner installation by keeping the FPR out of the engine bay.
