"HELP"How to put my injectors in my victor jr intake?"ASAP"
ok im gonna look right now and post a pic for some reason i think the bottom is a tad bigger i did buy them use of guy on sight here autosay97 and he said they will work cuz the top pop right in on my fuel rails! if it is bigger can i buy smaller o rings....
if you have your stock injectors you can use the upper ones as long as they are not cracked.. the oem are viton on the top. the bottom are buna and should not be reused, if you need a set you can get them at any auto parts store or I can send you some if you can wait
i went on ur link and went under instructions and it help me out a lot i believe i got them ! but y use they soap i just put a lil pb blaster on finger wiped around o ring and rock them in....
![](http://i858.photobucket.com/albums/ab144/STINGERRR/IMAG0020.jpg)
![](http://i858.photobucket.com/albums/ab144/STINGERRR/IMAG0019.jpg)
![](http://i858.photobucket.com/albums/ab144/STINGERRR/IMAG0021.jpg)
![](http://i858.photobucket.com/albums/ab144/STINGERRR/IMAG0022.jpg)
