Bad Fuel Pump?
Key on without engine running: 22psi
Key on with engine running: bouncing around from 20-25psi
The Haynes manual I have says I should be around 41-47psi. Bad fuel pump? Bad fuel pressure regulator? Is there a way to test which is bad for sure?
Thanks in advance!
Reg test: Pull the vac line off, and see if there's fuel in it.
That WILL cause the stink, black smoke and fubar plugs..
