Anyone ever put a sump in the stock plastic tank?
Old 02-28-2011, 08:44 PM
enginjoe's Avatar
Default Anyone ever put a sump in the stock plastic tank?
I did it on the neon and it worked great. Has this been done on an Fbody? Here's the neon job detailed out:
http://www.srtforums.com/forums/f187...4-pics-590539/
I am finishing up my new build and I'm going to need around 1000hp worth of fuel on E85 (1300hp reg gas). If I could get a sump like in the above pics, I could run a -10 from the sump to a really big pump with a -10 or -8 feed to the rails and a -6 return to the sump. I've never removed my tank, since I cheated and cut a hole for the Walbro install, so I don't know what the clearance is for something like this.
Old 03-16-2011, 09:57 PM
enginjoe's Avatar
Guess not...
Old 03-16-2011, 10:36 PM
bgblockelcamino's Avatar
was looking at those sumps. i will prob try it some day. looks like it will work too. i usually got a steel 98 tank sumped it. but i want to try this next time as loks like a good alternative since already have the plastic tanks
Old 03-16-2011, 11:38 PM
I_Need_Land's Avatar
dude i JUST posted in here within the past week YOUR thread lol, using that hellman perf sump. i got NO replies whatsoever.
https://ls1tech.com/forums/fueling-i...fuel-sump.html
Old 03-16-2011, 11:43 PM
enginjoe's Avatar
:crickets:
Yeah, I've been out of town and working 16 hour days, so I missed your post. That's funny. Anyway, it worked beautiful on the neon. It was a little overkill, but I needed more fuel and who knows what I'll do with the car later. It put down 478hp/508tq on a dynojet at a conservative 26psi on E85. That's the way I drive it every day. I figure, since I'm doing this forged motor front mount turbo thing with the SS, I could use a bit more fuel...
Old 04-16-2011, 03:03 AM
Pwebbz28's Avatar
Just tried it and it wont work. The hole in the top of the tank inst big enough to get the flange inside
Old 04-16-2011, 12:34 PM
enginjoe's Avatar
Now there's something I never even thought about. Thanks for letting us know.
Old 04-16-2011, 12:41 PM
Pwebbz28's Avatar
Hopefully he let's me return it. Shame, I was really excited about this.
Old 04-17-2011, 11:09 PM
that is NOT what i wanted to hear, fuel system is next for my car.
Old 04-18-2011, 02:43 AM
Pwebbz28's Avatar
Only choice is a sumped metal tank or dual intank pumps. I prefer a single a1000 over twins
Old 04-20-2011, 03:46 PM
Pwebbz28's Avatar
Just talked to Hellman. He said to just cut the flange part of the sump in half to get it inside the tank. No adverse effects from this. I already purchased a metal tank to sump so I may just do this and sell it tO recoup some funds
Old 04-20-2011, 04:01 PM
enginjoe's Avatar
Haha! That's awesome. It's back on then.
Old 04-20-2011, 06:58 PM
Trl_ws6's Avatar
Get some pics up when this is done.
Old 04-20-2011, 07:26 PM
enginjoe's Avatar
I was sitting in a meeting today and thinking about this. I can't believe it's so simple, it was right there in front of us. :facepalm:
Old 04-20-2011, 08:37 PM
yea it does make sense.
Old 04-20-2011, 08:51 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I think it would be doable. Every car I own has a metal tank, but it is a cool idea. I think cutting the flange in half would work just the same.
Old 04-20-2011, 09:03 PM
enginjoe's Avatar
Well, I can tell you it works awesome in the neon. I can run that thing dry and I get no fuel starvation issues. The external pump (bosch 044) whines a bit when the tank gets low and I go around corners or stop fast, but under acceleration, all the fuel goes right to the sump.
Old 04-21-2011, 10:16 AM
Avengeance's Avatar
I just came to this thread to suggest this... since its just pressure on a gasket theres no reason it wont work.
Old 04-21-2011, 09:04 PM
Pwebbz28's Avatar
It's not an exact fit but I think I can trim on it some and make it work. You Ottawa have a completely flat area. I'll update after the weekend
Old 04-23-2011, 06:55 PM
MUSTANGBRKR02's Avatar
Anyone have dimensions fopr this? I want to see where it can go on a f-body tank.
Quick Reply: Anyone ever put a sump in the stock plastic tank?
