Fuel pump for 02 Firebird?
Old Mar 6, 2011 | 08:58 PM
228bluebird's Avatar
Exclamation Fuel pump for 02 Firebird?
Is there an acdelco fuel pump i can use on my 2002 3.8 firebird.
I know advanced auto parts lists the EP381, EP386, and EP378.
My uncle took a look at the EP378 and he said it didn't have a connection
for the little black hose that goes in the bucket... I don't feel like buying the whole assembly... does the walbro have a connection for this black hose or do i have to do some modifications.... if i do have to make modifications for the walbro, is there an acdelco that will work with some modifications like the walbro??????
Old Mar 7, 2011 | 07:23 AM
Ollie8974's Avatar
Yes, The Walbro fuel pumps sold by the vendors on this board are direct replacement for the ACDelco. Support the vendors who support these forums.
Old Mar 7, 2011 | 12:35 PM
Ok, I found out racetronix has the moded walbro pump that a direct replacement for my acdelco pump, does any one know a reliable vendor of this racetronix pump or the direct racetronix site if they have one
Old Mar 7, 2011 | 12:40 PM
ZexGX's Avatar
I just used a stock 01 LS1 fuel pump+bucket assembly+sending unit in my '99 3.8L Firebird and it worked the same as normal. As a bonus, when I did an LS1 swap I didn't have to swap fuel pumps. You can also buy used fuel pumps here on LS1tech in the classifieds section.
Old Mar 7, 2011 | 05:35 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We have three options for a 99-02 Firebird / Camaro:
Genuine GM replacement:
http://www.racetronix.biz/itemdesc.a...A-F99D&eq=&Tp=
Racetronix / Walbro mild upgrade:
http://www.racetronix.biz/itemdesc.a...PA-016&eq=&Tp=
Racetronix / Walbro HP upgrade:
http://www.racetronix.biz/itemdesc.a...PA-001&eq=&Tp=
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 7, 2011 | 05:39 PM
BlackBirdDaddy's Avatar
I am also in the market for a Racetronix FPA-001. I have researched and the prices seem to be consistent around $149. Any other deals out there that exsist?
Thanks,
Jim
Old Mar 7, 2011 | 05:47 PM
from what i seen racetronix has the performance one for 150 and the replacement for factory (still a walbro, and therefore stronger than stock) fore 107... i'm going to do a quick check to see if theres a vendor that has them instock around the houston tx area if not i'll be ordering from racetronix tonight
Old Mar 7, 2011 | 05:57 PM
Racetronix's Avatar
LS1TECH Sponsor
Texas Speed ...
__________________
>WEB SITE<
Old Mar 8, 2011 | 01:01 PM
thanks racetronix.. I couldn't find one available in my area so i just placed my order
Old Mar 10, 2011 | 08:26 AM
Same here, just placed order. THANKS!
Jim
