E85 Guru...
Old May 7, 2011 | 10:02 PM
LS1NOVA's Avatar
You can get the regulator in black.
Old May 12, 2011 | 04:41 PM
Chicago TDP's Avatar
Order it from jegggs....call them and ask for Black, that is what I did...
Old May 12, 2011 | 04:47 PM
FakeSnake's Avatar
im going with the aeromotive belt driven setup and being done with it... -10 supply and return will be able to handle anything i throw at it and wont have to worry about voltage drops either...
Old May 13, 2011 | 10:23 AM
MSURacing's Avatar
I know it is more spendy, but I would also recommend the big Magnafuel pump and then use a weldon PWM fuel pump controller from FIC. This way, you have a big enough pump, but you are not going to overheat the fuel when you are just cruising around town.
Old May 13, 2011 | 10:27 AM
FakeSnake's Avatar
there wont be any cruising, this is a track only build that i will be working on...
