Setting fuel pressure...
Old 05-17-2011, 12:33 PM
salemetro's Avatar
Default Setting fuel pressure...
I'm wondering what the proper procedure for setting "base" fuel pressure is.
Currently, I have it set with the car not running at 55psi (my target base pressure). When I start the car, it goes down to 46psi @ 16hg. I'm assuming that this is correct, as the regulator is referencing the vacuum in the intake?
I guess that I'm really just not sure if "base" pressure should be set with the car at idle, or as I have it set up currently?
Old 05-17-2011, 02:57 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Start the car & with it running, adjust the pressure with the vacuum line disconnected.
Then hook the line up & note the idle pressure ... it will drop approx .5lb per inch of vacuum.
Old 05-17-2011, 03:32 PM
salemetro's Avatar
Ah...that makes sense. Thanks!
Old 05-17-2011, 04:28 PM
bridges's Avatar
Is it the same procedure for fi cars?
Old 05-17-2011, 05:21 PM
salemetro's Avatar
Let's hope so, cuz mine is LOL. Seriously though, I can't see how there would be any difference between N/A vs FI.
Old 05-17-2011, 07:14 PM
Old Geezer's Avatar
The IFR should also be set to a constant value if the reg is vac referenced....
Old 05-18-2011, 09:13 PM
joecar's Avatar
+1 set the pressure with the vacuum hose disconnected.
The pressure you set it to will be needed to recalculate the IFR table; or you can set the pressure to 58 psi.
+1 IFR table will be flat (same value in all cells).
Quick Reply: Setting fuel pressure...
