Recommended fuel pump and injector sizes?
I bought a vortech v-9 g-trim supercharger kit without the aftercooler. I am also doing 1 7/8 lt headers, magnaflow catback, an ls6 intake manifold, and p&p throttle body. I will be running between 5-8 lbs of boost at the most. The guy I bought it from gave me 32# injectors (that's what he says they are) and no fuel pump. I know I will need bigger injectors, so how high should I go? Also what fuel pump should I get?
Thanks and if anyone has anything else to add, let me know.
I'm really not sure on the rwhp at all. The guy I bought it said he was at 425 with a set up similar to what I am doing. But I want to have room for additional mods in the future up to maybe 500rwhp if I decide heads/cam down the road.
48lb injectors at LS1 pressure will flow 55.5 and will support 500RWHP
I have our design III Bosch in 48lb, flow matched within 1%, viton o-rings installed, and our 3 year no questions warranty for $299.
For the pump a 255 will support it, I don't stock them but I have our 340lph pump, same dimensions as a 255, that is on sale right now for $130 with the universal install kit.
![](http://img.photobucket.com/albums/v372/Mekanic/Injectors/pumpspecs.jpg)
FICINJECTORS, do you stock 60# injectors? If so how much is that set? I just don't want to be redoing injectors down the road if I don't have to and get the higher ones now. Or maybe what's the next step up from 48#s?
I have 60lb Siemens for $369.95 for the set, and I also have Bosch Design IV in 60lb for $389.
The Bosch IV is the latest design injector, and have amazing performance, They include the harness adapters.
![](http://www.corvetteinjectors.com/shop/ccdata/images/imageMain_17_354.jpg)
the 60's, at least if rated at 3 bar like most are, will flow almost 70 at LSx 4 bar pressure, making them capable of nearly 750CHP N/A
That said, we supply injectors for A&A Corvette for their supercharger systems, for the LS1 kit they use Siemens 60's, for LS2/3/7 they use our EV14 Design IV 60's.
Will I need harness adapters if I went with the Siemens 60lb injectors? I havent even taken apart my LS6 intake manifold that I will be installing when I do this to check things out yet...
Ok. Also does anyone on here know what part number of aeromotive 340 stealth in tank fuel pump I will need? There are three different ones that are all... well... different.
I have an ls3 that was running 3psi of boost in my 2001 camaro ss. It was using the 36# ls3 injectors and running rich as hell.
I am going to bump it up to 10 to 12 psi and wondered if I get 60# injectors, will i need a new fuel pump as well?
Stock ls1 pump with the inline fuel pump outside of the tank going to holley fuel rails.
