Guys with Boost-Referenced Regulator...
Old Mar 7, 2004 | 10:04 AM
Black LS1 T/A's Avatar
Moderator
Default Guys with Boost-Referenced Regulator...
Since I'm at 58 ~ 60 PSI Fuel Pressure and peak at about 13 ~ 14 PSI boost, is there a way to have the Boost Ref regulator rise at, say 1/2 PSI per 1 PSI of boost, and see if that is enough? Won't 71 ~ 74 PSI fuel pressure be too much fuel pressure for my system?
Sorry... I seem to be a novice dancing into new territory every so often.
Tell me what you guys do and what is sane. Thanks!
Old Mar 7, 2004 | 03:39 PM
y2khawk's Avatar
That pressure is fine. The whole idea of having a referenced regulator is to keep a constant pressure across the injectors, and not playing games with a varying injector flow rate. Not rising 1:1 would defeat the purpose
Only thing to watch is how much the pump flows at that pressure. Generally, flow drops as pressure goes up. But even a Walbro 340 is fine over 70psi
Old Mar 7, 2004 | 04:36 PM
NA$TY-TA's Avatar
How about the same thing you said harlan but with a Bosch 420L @ say 75 psi of fuel pressure running around 650rwhp..... shouldnt it still flow enough to support that much rwhp?
Thanks
Kyle
Old Mar 7, 2004 | 08:54 PM
BIGBOS's Avatar
I'm wondering the same....
Old Mar 7, 2004 | 09:13 PM
cablebandit's Avatar
you could start with a lower base if that makes you more comfortable. You want it to rise 1:1 as Harlan said so maybe try a lower base fp if you are trying to limit the total fp under boost.
Old Mar 7, 2004 | 11:47 PM
NA$TY-TA's Avatar
Thats sounds good to me..... Bos what does your fuel pressure sit at, at idle.........
Kyle
Old Mar 8, 2004 | 12:06 AM
BIGBOS's Avatar
Kyle
61-62psi on the gauge, until I started to run out of fuel today, due to my faulty gas gauge that I didn't know was faulty......dropped down to 45psi and that 420L got LOUD
Old Mar 8, 2004 | 02:45 AM
NA$TY-TA's Avatar
Damn dude i hope you didnt hurt the pump..... whats it see at WOT.... does it drop???? Ill be ordering all my fuel fittings and lines this friday before SBSO and get my tank sumped. Hoe did speed inc hook up your tank?? From your pics it looks as if its on top of the tank...
Kyle
Old Mar 8, 2004 | 09:01 AM
Moderator
Thanks for the advice guys!
What I got out of that is that I really don't have to worry about the max fuel pressure for this level of boost, but, if I find I don't need that much, I can start at a lower base pressure and give it what FP it needs.
Thanks, again!
Old Mar 8, 2004 | 03:06 PM
BIGBOS's Avatar
I'm sure the pump is ok, I was driving it today some more.......put more gas in it...
I will not go WOT w/the car until its said and done w/tuning........I'll let the tuner take care of that on the dyno.....
Old Mar 10, 2004 | 07:37 AM
MIGHTYMOUSE's Avatar
my system has run fine over 80psi but more than that peak and i would lower the base fp.
Old Mar 10, 2004 | 02:52 PM
Moderator
Thanks, MightyMouse.
