Walbro 400 lph Fuel Pump
Old 06-12-2012, 09:47 AM
  #41
kyoytey1693's Avatar
Ok. How about a ballpark idea? For example, this A1000 says it's good for 1300hp N/A and 1000hp FI in fuel injected applications.
Old 06-12-2012, 10:30 AM
  #42
LS1TECH Sponsor
Racetronix's Avatar
Approximately 800FWHP @ 58PSI @ 13.5V @ 0.6BSFC (FI)
Approximately 975FWHP @ 58PSI @ 13.5V @ 0.5BSFC (NA)
Hot fuel, line loss, elevated pressure, lower voltage, etc. will all reduce actual supported HP.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 06-12-2012, 10:57 AM
  #43
BashamWS6 Troll Account
ComeAtMeBro's Avatar
need to make this the size of the 255s
Old 06-12-2012, 11:07 AM
  #44
LS1TECH Sponsor
Racetronix's Avatar
Impossible if the same spec is to be maintained. It takes a larger turbine to move more fuel without adding more heat, armature RPM and power demands.
__________________
>WEB SITE<
Old 06-12-2012, 11:09 AM
  #45
innovation lol
Old 06-12-2012, 11:54 AM
  #46
Awesome! Thank you!
Old 06-19-2012, 10:11 AM
  #47
Powered By V8's Avatar
So is the walbro 400 100% not going to fit in a GTO bucket? Would any modification (like the kind of modification you do to get the 255 in) work to make this pump fit?
Old 01-30-2013, 05:41 PM
  #48
JoshuaGrooms83's Avatar
ok, so is it possible to retrofit this into a 98ls1 fbody? ive already installed a 255 and hotwire but when i need more fuel (which i think i will) but im already running a BR-FPR with a 3/8 line running back to the tank. would this support this pump?
Old 01-30-2013, 06:33 PM
  #49
LS1TECH Sponsor
Racetronix's Avatar
The factory wiring and lines are not enough to support the F90000267 pump.
__________________
>WEB SITE<
Old 01-30-2013, 06:45 PM
  #50
i undersand my 3/8" hard line is close to 6an hose line for return, might be slightly smaller but very close. but the stock fuel feed lines are not enough?
also i was more asking about the racetronix hotwire and will it support the 400? i already have this.
Old 01-31-2013, 12:48 AM
  #51
LS1TECH Sponsor
Racetronix's Avatar
The hotwire is fine. The sender's bulkhead wiring, in-tank wiring and fuel tubes are not.
__________________
>WEB SITE<
Old 01-31-2013, 09:06 AM
  #52
1999Black_Z28's Avatar
98 is not same as 99-02
This pump will not fit the 99-02 bucket w/o mods.
This pump will not function properly with the factory regulator in the 99-02 system.
We are working on a system solution expected this summer.
Any updates?
Old 01-31-2013, 09:55 AM
  #53
ok, so at this point larger AN hose lines and a complete direct wiring from the sender and tank to the hotwire is required then. Any development for a harness to plug and play from the new pump and sender to the hotwire in the works?
Old 02-03-2013, 11:37 PM
  #54
LS1TECH Sponsor
Racetronix's Avatar
We have offered an harness solution for the 99-02 modules for over a year now:
http://www.racetronix.biz/customkiti...=FPWK-017W&eq=
The in-tank harness is setup for a Walbro GSS-series pump. The connector could be easily replaced with terminals for other pumps.
__________________
>WEB SITE<
Old 02-04-2013, 06:34 AM
  #55
djt81185's Avatar
I've bought this pump, injectors, efan harness, and other bits from you to install in a 98 trans am (also have your 98 hotwire kit and regular pump upgrade installed currently). What would I need to do to adapt this above harness kit to my 98 fuel tank setup. Are the bulkheads the same?
Thanks,
Dan
Old 02-05-2013, 06:51 PM
  #56
HRHohio's Avatar
I have the Racetronix Hot Wire Kit in my '02 Camaro and had an Aeromotive 340 in (until it burned out right after I installed the Hot Wire Kit... NOT saying it's the Hotwire Kit's fault...my previous builder probably should have upgraded the wiring if BEFORE he was putting in the AM340, I think)...
Anyway, you say "the pump will not function properly with the factory regulator." What is the maximum flow the factory fuel regulator at the bucket can handle?
It handles the W255, AM340, DW300 fine, or? What about the Walbro 400 (p/n F90000262 (non-E85)
http://www.racetronix.biz/itemdesc.a...000262&eq=&Tp=
In other words, can I drop this in and replace my Walbro 255 with current setup (Stock Fuel lines, rail, fuel pressure regulator, Racetronix Hot Wire).
Thanks in advance!
Hayden
Old 02-10-2013, 01:13 AM
  #57
HRHohio's Avatar
Bump. Anyone know what the stock FPR's max out at for flow?
Old 02-10-2013, 02:57 AM
  #58
Mrmooney's Avatar
isnt there people running 2 walrbos 255 through stock FPR's?
I would think the 400 would be fine?
Old 02-10-2013, 08:25 PM
  #59
Most people with dual 255's only run one until boost hits. From what I understand the issue with the 400 is at idle and non-WOT
Old 02-11-2013, 04:03 PM
  #60
HRHohio's Avatar
Well, I swapped one in this weekend. Test drive... no issues at WOT or at idle. Read somewhere where an independent flow test showed that it flowed LESS than an Aeromotive 340 @58psi. I figured I had an AE340 in for 6 months (until it burned out), so my setup should be able to handle this one. So far, so good.
Quick Reply: Walbro 400 lph Fuel Pump
