Racetronix pump problem?
As for pressure loss, you need a gauge to see how the pressure holds after you shut the car off, this will tell you if there is a leak somewhere.
Regulators generally hold pressure for a long time, but as they age,it is possible to bleed off after a while. Nothing to worry about if you lose pressure after a couple minutes, but it will take time to build the pressure back up.
The first racetronix kit I had worked just like the stock pump I never had to prime it and it always started on key. The issue here is that it was literally working just fine with the old pump however my nerves got the best of me and being that the old pump had 125k on it I decided to replace it. On friday the car drove just fine and never had to be primed after sitting I installed the new pump and now I have an issue this would lead me away from the regulator and more towards the new pump.
Since the original post I got a pressure tester at autozone and tested the fuel rail upon start up I have around 60 psi however after turning the key off it will bleed down to about 20 and even lower over time. So either I have an internal leak in the tank somewhere or the check valve in the pump is bad. Once again a bad regulator could cause this but for it to be working just fine with the stock pump and then to have it fail right when the new one went in is too much of a coincidence.
I have contacted racetronix and they instructed me to prime the pump in fuel with it out of the car and inspect the plastic hose to see if it leaks which I will be doing tomorrow.
Anyway the psi on the gauge went to 90 for a split second then bled down to about 75, over the course of the next 45 minutes the psi bled down to about 35psi I watched the pump the whole time no fuel leaked from any of the hoses at any time and the fuel regulator did not leak fuel either. once again i never had this issue with my old pump (except for it losing psi at 6500 rpms) and the odds of the regulator going bad the same day I replace the fuel pump are highly unlikely in my eyes.
I've bought a couple racetronix pumps before and never had an issue I would just like to get this resolved and swap in a new pump as I really feel like there is a bad check valve in the pump.
I am guessing that you did not leave the factory fuel lines connected when you tested it.
That other hole is the pressure relief that prevents pump damage.
If it takes a few minutes for the pressure to fall to zero, the regulator or pump is not bleeding off enough pressure to worry about.
FYI, never operate the pump out of the tank in a bucket of gasoline. One spark & you may be living in a burn unit at the nearest hospital.
Also regardless of how long it take to bleed off pressure it still shouldnt be doing that. The fact that it is bleeding off pressure down to 35 psi and still falling would explain my hard starts after letting the car sit over night. While I know it isnt a serious issue I still dont want to have to prime my car every morning after I just installed a new pump. I have used racetronix pumps before and havent had this issue.
Once again heres how I look at it my old factory pump still worked it just fell off at 6500 rpm a bit. But every morning the car started right up on the first crank and was ok. The last day I had that pump in was Friday that day I replaced it with a racetronix pump this is the ONLY thing that was changed and now I have a problem with hard starts every morning or even letting the car sit for a while and after seeing it bleed down to 35psi is evident that something is wrong. The odds of the regulator starting to leak the day that I put the racetronix pump in are pretty slim i think anyway.
I hope I didnt come off rude or anything but you all have to understand where I'm coming from going from a factory pump that didnt have this issue to a new racetronix pump and having this issue and then having people tell me its not the pump or its nothing to worry about is just getting a little old. I have since ordered a new pump btw but this is still frustrating
i hear ya..
i made the hose a tad bit long so it would help push the punp down and to where i had to slightly push down on the module,and still allow it to lock in place. (lock ring)
aeroquip is not recommended,it is not a submersible fuel line.
Gates: PN 27097 is a submersible "rated" SAE J30R10
It sucks, but I'm quickly finding that fuel systems are very finicky.
i do have a voltage drop at wide open throttle do the the pump drawing to much power from the alternator.
FIX
i am going to install a truck alternator and the hot wire kit.
then back to the dyno for the final tune
