Who makes the Best Fuel Injectors?
I was curious on fuel injectors and wanted to know if anyone had any input on which company makes the best fuel injectors. I looked at the FAST fuel injectors they had high and low impedence. I'm not sure what that means so if someone could elaborate, please do.
:drive
:drive
They do make converter (versafuler) box for low impedance injectors so you can use them with the factory PCM, but unless your making BIG power, you should be able to find an injector that meets your need in a high impedance injector.
FAST makes good injectors but you can check out FIC as well, they have good deals on injectors and can even upgrade your factory ones.
Injector Dynamic sells high dollar dynamically matched fuel injectors. There has been some long debate threads on other forums about weather or not its worth the cost. I don't think they sell anything under a 70 pounder.
Hope this helps, what are your plans for the car?
Be sure to check us out before making a purchase.
http://www.deatschwerks.com/modern-muscle
If you have any questions, please ask.
All DW injectors come with the Static and Dynamic flow rates of each injectors and % (<2%) difference of each injector and how they relate to one another.
The estimated system limits of the injectors at 70%-90% Injectors Duty Cycles
...and fuel pressure correction from 30psi to 80psi.
I'll have to look them up. Tuning for new injectors shouldn't be a guessing game.
I don't really know who makes this stuff but I have some facts that Diesel is a dirty fuel. It produces lots of carbon deposits that can affect the performance of your engine. That is why it is important that you keep your fuel injectors clean.
If you hire an expert to clean your fuel injectors, you need a lot of money. But, if you are on a tight budget, you can do it on your own with the help of the best diesel injector cleaner.
best for what ?
Ahhh fer ***** sake, it's another bloody dead thread digger !!
