My plastic bucket mod for dual walbro pumps ...
I am looking to add another pump also but I already have a racectronics Intake pump w Hot wire kit installed, Would I be able to add in 1 walbro pump and would I have to run another hotwire kit for the pump I add? Thx
Thanks for the MM stamp of approval Dave!
Firehawk, yea or run your own 10g wire and a good relay. like that they'll be on all the time or you can set the second up to run off a hobbs switch. should be some info in here somewhere on how to add that in if you search for it. i'll be doing that soon myself so i'm not cycling fuel as quickly and heating it up.
where did you get the fittings from? Have part #'s?
EDIT, found it!
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
EDIT, found it!
