Fitting type at fuel filter?
I'm trying to build a fuel system for LSx swap into older car. Using the Camaro LS1 fuel filter but I don't know what type of fitting is used on the threaded end of the filter. Anybody know?
Here are two examples. I'm guessing it is one of these styles?
![](http://i1137.photobucket.com/albums/n515/QwkTrip/4770d03c.jpg)
Kleeborp the Moderator™
Assuming it is the same as the return line on the t-block of the f-body fuel system, it is a 14mm x 1.5 o-ring fitting (Russel Part # 648070 [14mm x 1.5 O-ring to -6AN] is the correct adapter for the t-block to convert it to -6AN). So the fitting on the right in your picture.
