500 rwhp Fuel help advice
I am just curious if I need to upgrade my fuel system anymore mods listed below
98 m6 full boltons (ls6 intake) Cam Racetronixs Pump and hot wire kit (100 shot nitrous wet) stock rails injectors
416 rwhp NA
500 rwhp 100 shot of Nitrous
416 rwhp NA
your getting close to maxing the injectors out on N/A but you should be ok.
I had to have my LS3s rebuild to 50psi from where I have seen others max them out with the same setup as I have. but you should be just fine a wet setup dosnt use any more fuel from your injectors it gets its own. I run the same pump for 500rwhp NA. any future upgrades might merit for going up a little on injector size. you can always find out what there duty cycle is if you put it on a dyno
Thanks for the info
Should I upgrade my fuel rails is it needed? Or will it screw **** up with my tune? I found some used fuel rails for a good deal just about to pull the trigger
