street legality...
Old Sep 29, 2012 | 12:55 PM
nick.celis's Avatar
-8 feed and -6 should suit you just fine.
Old Sep 30, 2012 | 08:34 PM
trevmust's Avatar
6 return?
Old Sep 30, 2012 | 10:36 PM
My6speedZ's Avatar
To keep the fuel from heating up.
Or if your running twin in-tanks, just use the stock feed as a return and shut one of the pumps off with a hobbs switch.
Old Sep 30, 2012 | 11:06 PM
trevmust's Avatar
you just spoke chinese... I'm putting the LS into a second gen f-body
Old Sep 30, 2012 | 11:15 PM
1999CamaroSS's Avatar
Originally Posted by wws699
Yes, but unless you have a Corvette motor it wont do you any good
You have a Corvette motor right?
Old Oct 1, 2012 | 04:09 AM
nick.celis's Avatar
Ok, basically, your FEED line should be a -8 and the return should be a -6an. This will give you room to grow, and will help the fuel not overheat. Since you are not using the Stock feed for a return(obviously) run the said feed and return mentioned. It is a no brainer. Are you using an external pump or an intank pump?
Old Oct 1, 2012 | 12:36 PM
My6speedZ's Avatar
Old Oct 2, 2012 | 04:20 AM
nick.celis's Avatar
If using an external pump, i would look at getting a sumped tank. As much as you may not want to hear it, but using an external pump and pulling from the top doesnt sound like a good idea IMHO
Old Oct 2, 2012 | 09:50 AM
My6speedZ's Avatar
If your car has a metal tank and you know a good fabricator they can even sump your current tank, and likely wouldn't cost more than a few hundred bucks.
Old Oct 2, 2012 | 11:00 AM
trevmust's Avatar
I'm using an in tank pump.
Old Oct 2, 2012 | 11:05 AM
nick.celis's Avatar
even easier. just run the -8 feed off the sending unit, and a -6 return to the fuel tank!
Old Oct 2, 2012 | 01:36 PM
  #32
Nasty N8's Avatar
Give me a call I can set you up with a complete line kit for your needs.
http://www.nastyperformance.com/shop...fuel-line-kit/
Old Oct 2, 2012 | 01:41 PM
  #33
ZL1Killa's Avatar
N8 will provide all you will need and give you all the details. go for it.
Old Oct 2, 2012 | 04:17 PM
  #34
trevmust's Avatar
thanks, I checked it out.
Old Oct 2, 2012 | 11:05 PM
  #35
nick.celis's Avatar
Nasty N8 is a great guy, talked to him yesterday, ill be ordering my sumped tank from him tomorrow!
Old Oct 3, 2012 | 07:14 PM
  #36
My6speedZ's Avatar
His f-body tank looks sweet, I have checked it out before too. The whole kit (lines, tank, pump, and rails) is reasonably priced as well.
When you get it post up some pic's I'd love to see some installed pictures. It's nice he makes a good metal tank for us plastic tank guys .
Old Oct 3, 2012 | 09:20 PM
  #37
nick.celis's Avatar
will do!
Old Oct 5, 2012 | 03:46 PM
  #38
Danny's Avatar
What if instead of installing a sump you fab up a hardline coming from the tank lid to the bottom of the tank. Just measure from the bottom of the tank to where the lid sits while installed. Then cut a hard line and install it onto the tank lid. It should have the same efficiency of a "in-tank" fuel pump setup.
Just a thought...
To the OP,
I would check to see if the braided line is DOT approved. If so, then you're good to go. Personally I don't see a reason why it wouldn't be but sometimes there's these dumb *** laws out there that prohibit certain things.
Old Oct 7, 2012 | 12:09 PM
  #39
trevmust's Avatar
I saw PTFE lines (teflon) and they are racecar approved.... so I think they should work
Old Oct 7, 2012 | 12:24 PM
  #40
nick.celis's Avatar
Glad to hear you got it worked out!
