Can you run a Boost Reference Fuel Pressure Regulator with Stock LS1 Rails?
Sorry if I wasn't clear with my wording. I said "toward" a real fuel rail with the intention that if you ever want to move past this level of power any money spent converting the stock rail to have a return and regulator would only be removed when changing to an aftermarket rail.
I don't even look at what just a rail costs, Lonnie's perfomance has a system double pumper system thats $1000, Includes -8 Supply & -6 Return lines, fuel rails, regulator, filter, & all fittings needed to connect to double pumper sending unit.
I know the OPs car very well. None of what we are talking about is necessarily for it =) It just has a history of not behaving.
If we were talking 20+psi and a 255 pump, then maybe this would be an issue but @ or below 15lbs, 60lb injectors + 340 pump and meth, if your all your parts are working then there is no issue.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Here is what I did. 97-98 vette rails, replaced the factory vette regulator on the rail with a f-body pulse damper, used the vette stainless lines, added a Fuelab mini regulator on the return side of the rails, ran a new 5/16 return line back to the hard line near the tank, and removed the regulator in the stock tank.
This could also be accomplished using the shrader valve port as well.
![Name: Fuel2.jpg
Size: 127.4 KB](https://ls1tech.com/forums/attachments/fueling-injection/611934d1501331080-can-you-run-boost-reference-fuel-pressure-regulator-stock-ls1-rails-fuel2.jpg)
![Name: Fuel1.jpg
Size: 130.6 KB](https://ls1tech.com/forums/attachments/fueling-injection/611935d1501331080-can-you-run-boost-reference-fuel-pressure-regulator-stock-ls1-rails-fuel1.jpg)
![Name: Fuel2.jpg
![Name: Fuel1.jpg
![Name: Newy-pipe1.jpg
Size: 89.1 KB](https://ls1tech.com/forums/attachments/fueling-injection/611936d1501331080-can-you-run-boost-reference-fuel-pressure-regulator-stock-ls1-rails-newy-pipe1.jpg)
Did you install this 97 rail setup before or after you knew the Stock regulator would work 1:1 with boost.
For people that don't know the 97 rail was meant to have a rail based regulator that works great for boosted application, the original factory unit isn't adjustable but there are a select set of truck regulators that are adjustable. ( if you need to make changes to the pressure )
Sorry for the crappy pic.
![Can you run a Boost Reference Fuel Pressure Regulator with Stock LS1 Rails?-1ddv5.jpg](https://ls1tech.com/forums/attachments/fueling-injection/728659d1683241273t-can-you-run-boost-reference-fuel-pressure-regulator-stock-ls1-rails-1ddv5.jpg)
The stock regulator is NOT 1:1 boost referenced, its basically vacuum referenced only.
I previously had an aftermarket adjustable regulator in the 97-98 stock rail location. I would only gain about 4-5psi of fuel pressure max when running 10psi boost.
Not trying to say you are wrong, just trying to get to the bottom of it. been a while since I've ran one and don't remember it being an issue. Im using a 97 rail with regulator but its not currently boosted so I can't just go out and check it.
https://ls1tech.com/forums/forced-in...regulated.html
Did you end up doing your own testing or did you find other research.
thought id throw mine up here since i did it lol
i used a 3/8 hard line instead of an hoses. too expensive lol just a slight pain to route to make it look pretty. that part took the longest. but the outcome was well worth the effort. its a solid line from front to back. im not sure how i did it lol but i did
![Name: P1040677_zps30772556.jpg
Size: 108.9 KB](https://ls1tech.com/forums/attachments/fueling-injection/610008d1501327011-can-you-run-boost-reference-fuel-pressure-regulator-stock-ls1-rails-p1040677_zps30772556.jpg)
![Name: P1040676_zps07b35020.jpg
Size: 75.2 KB](https://ls1tech.com/forums/attachments/fueling-injection/610009d1501327011-can-you-run-boost-reference-fuel-pressure-regulator-stock-ls1-rails-p1040676_zps07b35020.jpg)
