fast fuel rails
Old Oct 7, 2012 | 06:01 PM
BSGTOLS2's Avatar
Default fast fuel rails
i got a set of fast fuel rails anything i need to know before trying to put them on my ls2 intake
Old Oct 7, 2012 | 06:36 PM
99Bluz28's Avatar
You'll want safety glasses, then blow down the engine good with either a shop vac or air compressor. Make sure you have a cool or cold engine, release fuel pressure, remove fuel pump fuse, an have shop rags and container to catch any fuel. Before ever installing the fuel rails lobe the O-rings and injector o-rings(replace if damaged) with fresh engine oil, and don't over tighted the fuel rail fittings, otherwise you'll create a leak either now or later. Finally varify there's no fuel leaks before running the engine for more then a few seconds.
Oh, and make sure you have the fuel line disconnect tool, and that your fuel rail fitting and hoses have no debris in them. I usually just spray carb cleaner through them.
Old Oct 7, 2012 | 10:42 PM
BSGTOLS2's Avatar
thanks for the advice
Old Oct 8, 2012 | 11:41 AM
BSGTOLS2's Avatar
ok do i cut the factory fuel fitting off and hook it up to the supplied an fitting?
Old Oct 8, 2012 | 11:57 AM
BSGTOLS2's Avatar
or how do i hook up the fuel supply
Old Oct 8, 2012 | 04:37 PM
99Bluz28's Avatar
NO cutting! Use a fuel rail hardline disconnect tool where the soft line connects to the factory rail. You might also have to go back further and disconnect the softline where it connects to the hardline on the firewall. Sorry I don't have a GTO so I can't give you any more info, especially since I can't really find any good info; anyway good luck.
https://ls1tech.com/forums/pontiac-g...&daysprune=365
Old Oct 8, 2012 | 06:30 PM
BSGTOLS2's Avatar
thanks man
Old Oct 10, 2012 | 09:01 PM
99Bluz28's Avatar
So did you get everything installed ?
Old Oct 10, 2012 | 09:23 PM
BSGTOLS2's Avatar
Negative looks like the ones i got are for ls1 not ls2
Old Oct 10, 2012 | 10:39 PM
99Bluz28's Avatar
That sucks, hope you get that resolved soon.
