Car shows running lean
Old Oct 26, 2012 | 10:40 PM
smahlum_21's Avatar
Or can I just put a breather where the oil cap is?
Old Oct 26, 2012 | 11:24 PM
smahlum_21's Avatar
Also got time setup to get car on the dyno in Watertown SD. Tuner there thinks the MAF is what's giving me the lean codes. Said to put stock back on and see if goes away
Old Oct 26, 2012 | 11:42 PM
motoplattinum's Avatar
Definitely swap MAFs out and see if your codes go away. What is your exhaust setup? Are you still running factory cats? Lean codes could be set from poor catalyst flow preventing gases from being exhausted and polluting 02 readings as "lean" when otherwise suitable operating conditions are met. Where are your fuel trims? Have you verified this condition with a wideband?
Old Oct 27, 2012 | 11:28 PM
smahlum_21's Avatar
Threw away the stuff to use my stock MAF. I bought a smooth bellow and slp lid and doesn't fit with my setup. I'm just gonna park the car till I can get it tuned. Tuner said I could still drive with the slp maf but I think I'll just play it safe. I have not verified it is actually running lean. People I've talked to said when its showing lean bank 1 and 2 it is usually the maf or vacuum leak. I still have to check intake bolts to make sure disnt come loose too
