Bosch Green Giants work with FAST LSX 102?
Just as the title says. Need some skinny injectors for the FAST LSX 102 and have heard great things about the Bosch Green Giants. They are 42lbs at 3BAR.
Just wondering if they'd fit with the LS2 rail and adapter kit FAST sells and the FAST manifold?
I believe BayerZ28, can't remember his exact screen name, got the green tops to work on the Fast 102.
I don't know if you have seen this thread or not.
https://ls1tech.com/forums/generatio...02-thread.html
Yeah I have seen that. I knew you needed skinny injectors and the FAST kit. I plan to run the FAST kit, but it's hard to find info on whether an injector is skinny or fat.
Btw, these Bosch injectors are not "green tops"; those are Ford. Instead, these are Gen 3 Bosch injectors that were originally designed for a Volvo Turbo with an EV1 connector. They just happen to be green. And they are sold flow matched from Bosch and have a very good spray pattern and very good dynamic range. So they are a pretty nice piece and are very easy to tune. FI guys seem to love them.
The green tops are also Bosch. They were sold under ford racing and came in some of the ford lightnings. They flow very similar to the new gen3 "green giants" because it is the old green tops replacement.
I personally like either of those injectors. I've tuned quite a few cars with either of them and they all seem to run and drive awesome especially with the correct cal data!
I am running the older big body green tops in my fast102 and it is a tight fit but they are in there. I would like to later upgrade to the newer style just for the better spray pattern and efficiency.
Beware of the imitations on the market though. There are ALOT of Chinese knockoffs of the "green giant" floating around. They are NOT near as good of quality as the original Bosch's. You can tell if you have real ones if the Bosch part number is stamped into the body of the injector. 0 280 155 968
