fuel pump set up for 4th gen camaro
Good choice. Racetronix is the only kit with a direct drop in replacement because they took the time to develop their pump with the exact size specifications as the stock unit. They even took the time to add the jet pump feature so it still uses the venturi feed to keep the bucket full at all times. The internals of the Racetronix pump are much much better than a stock unit and as such flow more and will last just a long. Can't go wrong with Racetronix.
My builder told me this; You may need to upgrade the injectors too, but said do all your mods and fuel pump and obvioulsly you will need to dyno tune it and it will show right away if you need injectors.
Luckily I've only rcvd positive responses and experienced recommends on my questions and I can tell you there are some brilliant mechanics and engineers on this site if you can catch them with your questions. good luck
http://www.racetronix.biz/itemdesc.a...PA-001&eq=&Tp=
Is this the one you bought? Looks like the direct replacement for our 2001 F bodies.
