need help with hotwire kit
Old Mar 17, 2013 | 03:18 PM
bryan00ssm6's Avatar
Default need help with hotwire kit
I need help hooking up my racetronix fuel pump hot wire kit non of the plugs match. The rewire kit is the fphw-017 am I missing something. Also I didnt get the installation instructions like a lot of people apparently.
Old Mar 17, 2013 | 10:44 PM
LT1RAY's Avatar
What year is your car? Are you trying to plug them into the factory harness and fuel pump? Any pictures?
Old Mar 18, 2013 | 06:43 PM
Firebirdmuscle's Avatar
I hope mine goes in smoothly. My racetronix 255 and harness kit is on the way. Curious to hear more
Old Mar 18, 2013 | 07:54 PM
It's a 2000 ss. I got fuel pump done and intank. It says its plug and play but that's crap. The plugs that go to the top of the fuel pump don't match. No pics yet
Old Mar 18, 2013 | 09:19 PM
Ttt Anybody. I've tried the racetronix forum but that's been useless so far
Old Mar 18, 2013 | 11:19 PM
LT1RAY's Avatar
I can't remember off the top of my head but I believe one plugs to the factory harness and the other plugs into the pump. Have you verified you have the right harness? A picture would help. You could have got the 98 wiring harness.
Old Mar 18, 2013 | 11:24 PM
LT1RAY's Avatar
You should have this harness. I can't find the part number you listed on their site.
http://www.racetronix.biz/itemdesc.a...%2D001&eq=&Tp=
Old Mar 19, 2013 | 12:27 AM
From what I've seen they were phasing out the fpwh001 and these were the new ones but doesn't seem to work
Old Mar 19, 2013 | 01:32 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The harness installation is no different than the FPWH-001 other than that the module's bulkhead connector is replaced. People make the mistake of assuming the harness interfaces with the connectors located above the diff. This is incorrect. They interface at the module above the tank.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 19, 2013 | 02:43 AM
Racetronix's Avatar
LS1TECH Sponsor
When purchasing our new FPWH-017 please make sure it is in the kit format which is part number FPWK-017A/W/WX depending on your application:
http://www.racetronix.biz/customkiti...PWK%2D017A&eq=
http://www.racetronix.biz/customkiti...PWK%2D017W&eq=
http://www.racetronix.biz/mmWEBSTORE...WH-017x100.jpg
The kit contains the FPWH-017, bulkhead connector and in-tank harness.
__________________
>WEB SITE<
Old Apr 1, 2013 | 03:17 AM
roninsonic's Avatar
We can't help you without pictures, mate.
Old Apr 1, 2013 | 11:51 AM
WS.666's Avatar
Sounds like you are confusing the plugs that come through the body by the brake lines and differential with the plugs on top of the fuel tank. You need to either drop the tank and install the hotwire or cut a hole in the hatch above the fuel cell and fish the wires up from the bottom or run them inside the car and leave that cutout in the hatch open.
Old Apr 1, 2013 | 12:43 PM
Racetronix got me fixed up. I was sent the harness without a bulkhead adapter for the fbody.
