FINALLY you can stop eating budget pumps on E85
I show it working on my end, we will get it looked at. If you need to, call me in the morning and I'll get it put through myself, I'll even upgrade you to faster shipping if you'd like to make up for the troubles
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
The highest output in e85 that we stock is this one. I think walbro does a 400lph e85 pump that I can get though.
__________________
It's all in one box from the manufacturer
__________________
To the top, in stock!
__________________
Would these work ok on gas too? I need a new pump now but am not sure if I would switching to e85 at some point in the future. Or should I just get the standard gas version?
It will work perfectly on gas, just like the gas version. You'll just be paying a little more to know you are e85 compatible in the future if you decide to go that way.
__________________
#32
#33
Fresh stock is in! to the top!
__________________
#35
The only sock we have available is the one included in the kit.
__________________
#37
I purchased an HPT/Wideband kit from you not long ago. I wish I would have seen this before I had ordered, because I would have gotten these too.
Be expecting a call from me for a pair of these. Nothing wrong with my Walbros, but if I decide to switch to E85, these will make it as easy as swapping pumps and refilling the tank!
#38
What are you supposed to do with the small black wire on this thing?? I've searched but can't seem to find any install info for this pump.
Also, it doesn't use the stock venturi system, should the bucket be modified because of that?
