Fuel system wiring?
Since then I have tried multiple things. 1. changed fuel filter 2. changed regulator. 3. installed Racetronix hotwire kit (surprisingly the car ran great without it for years ) 4. Finally, dropped the tank again and removed the dual Walbros and swapped in dual Deatschwerks pumps yesterday thinking that maybe the Walbros were dying and not keeping up when put under demand.
Took her out for a couple "test passes" just now and damn it, the fuel pressure still drops under heavy throttle/boost!
Pumps prime just fine and idle fuel pressure is ~62 psi. Cruising around it is 60 psi. Put my foot in it and it drops into the 40's.
What I noticed when wiring in the new Deatschwerks pumps is that the factory wiring inside the tank from the top of the bucket to the pumps is about 2 sizes smaller than the gauge of the wiring that came with both the Walbro and Deatschwerks pumps. The factory harness that runs to the top of the bucket (external to the tank) looks to be one size smaller than the Deatschwerks/Walbro supplied wiring and the wiring from the plug leading down into the tank is two sizes smaller. I am starting to think that may now be the problem. I may be getting a substantial voltage drop (?). I had checked battery voltage at the battery and then back at the body mount when the factory harness plugs in and voltage was a match, but wonder what is happening further down the line leading to and inside the tank.
My question is are members doing a rewire of the stock wiring all the way from the pumps to the factory harness plug at the top of the bucket?
BTW, I checked for fuel leaks and detected none.
https://ls1tech.com/forums/fueling-injection/1679903-10-awg-hotwire-setup-ohm-s-law.html
It's a good idea to change the in tank wiring and the wiring that goes to the top bulkhead to 10 awg to match the Hotwire kit..
