01 LS1 injector size sufficient on 6.0
I'm building a LS2 thats going into my 01TA. Pretty much a stock LS2 with GM ASA cam and LT's. Are the stock LS1 injectors sufficient to feed the 6.0 or do I need to look at upgrading.
I was planning on sticking with the stock LS6 intake and Maf and TB unless I need to start looking at upgrading all of the above looking for input on injectors and stock intake tract..
Im sure you could get by with them since they are the 28# injectors, but IMO it might be a better idea to get something a little bigger like the 30# ford injectors that flow 36# on ls1 rails. Its better to have too much fuel injector than getting close to maxing what you have.
