Low vs high impedance injectors
Old 07-07-2014, 12:10 PM
Mike Cordero's Avatar
Default Low vs high impedance injectors
When to use which? Assembling a low comp. 408. Planning to use in a daily driven twin turbo 54 chevy truck. What if uses a flat top pistons (not low comp) in a non turbo car?
Old 07-09-2014, 10:54 AM
Moderator
jimmyblue's Avatar
All of our cars use high impedance injectors, what you
need (impedance-wise) follows the PCM and what its
internal driver circutiry is set up for. Low Z injectors
need a peak/hold driver, not the simple switch-to-ground
outputs that we have.
You can get proper impedance injectors with more flow
than you need.
Quick Reply: Low vs high impedance injectors
