Fittings from T-Block to AN
Old 07-27-2015, 07:22 PM
thunder57's Avatar
Default Fittings from T-Block to AN
Hello,
I have a 2000 fbody fuel tank I'm wanting to put into my 1987 Camaro. I'm wanting to keep the lines off the tank and just run one line up to the motor. How would I adapt the T-block to -6AN? I have included some pictures. Thanks.
Attached Thumbnails Fittings from T-Block to AN-img_20150726_160512.jpg   Fittings from T-Block to AN-img_20150726_160558.jpg   Fittings from T-Block to AN-img_20150726_160628.jpg
Old 07-28-2015, 12:01 AM
Fat Jesus 808's Avatar
most hydraulic fitting and hose stores would have a fitting for that.
Old 07-28-2015, 01:19 PM
jrpimp00's Avatar
If I remember correct I used a (14mm x 1.5 O-ring to -6AN) from Russel. You may want to double check the size.
http://www.summitracing.com/parts/rus-648070
Old 07-29-2015, 04:49 PM
thunder57's Avatar
Thanks! I'll give it a shot
Quick Reply: Fittings from T-Block to AN
