Alky control not getting full pressure when cutout is closed???
Just as the the says I took the car out yesterday and ran it from maybe 40-100mph 2 times and the red/green LED never went to green. Just to be clear I have never went WOT with the cutout closed before this time. I used the test button on the adjustable control module and the LED would only go to red. I open the cutout a little like I normally do and it instantly goes to green like it always has. Whats going on I wonder??? Has this happened to anyone else?
Ok, so I just got off the phone with Julio and man oh man do I feel like an ***. lol Apparently you should purge the kit once at the beginning of the day when boost is expected if its been a while since running the car. Ok, I hadnt drove the car in about 2 weeks and just decided to take it out for some long over due fun. The lines were not purged and the system wasnt seeing full pressure for the 1st couple of hits until I just happened to give it another try with the cutout open. It was probably just pure luck that the engine didnt skeet itself off all over the road like some kind of adult film or the like. Lucky me.
Did you turn the dial to #8 before purging it? If not Julio says that will not be enough to make the pump run hard enough to get the LED to turn green. I believe this was part of the reason mine didnt go green after the 1st run when I hit the test button.
I'm going to try it again this afternoon.
I took mine for another trial run and purged it before the hit this time. It worked like its supposed to. Its amazing what a little phone conversation can do these days. I was curious why Julio put instructions in the kit to start with. Guess Im lucky I had my kids around to read them for me or it might have not gotten installed correctly.
