Which Racetronix fuel pump kit?
Old Feb 2, 2016 | 02:45 PM
1995_maro_z's Avatar
Default Which Racetronix fuel pump kit?
On ws6store.com, there are 2 Racetronix pumps listed. The part numbers are: RFPK-001 and FPA-002A. What is the difference besides the price? Are both direct fits for 99-02 f bodies?
Old Feb 2, 2016 | 03:03 PM
HCI2000SS's Avatar
Can you post the links?
Old Feb 2, 2016 | 03:07 PM
http://www.ws6project.com/user_stor/...6c18424cef2e98
Vs
Old Feb 2, 2016 | 03:18 PM
HCI2000SS's Avatar
Just took a brief look, but it looks like one contains just the pump only and the other is pump and hot wire kit. Basically the hot wire kit will spin the pump a little harder, thus allowing you more room for power
Old Feb 2, 2016 | 07:12 PM
Will the kit w/out the hotwire kit still be a direct drop in with no modifications or splicing?
Old Feb 2, 2016 | 07:21 PM
HCI2000SS's Avatar
Yes. I actually run the one with the hot wire kit, and it was pretty simple
Old Feb 2, 2016 | 08:14 PM
Good deal. Thanks!
Old Feb 2, 2016 | 08:15 PM
HCI2000SS's Avatar
No problem
Old Feb 2, 2016 | 08:22 PM
Cajun ELESS-ONE's Avatar
if you run it without the hotwire kit, it puts a strain on the pump because it pulls more power then the stock pump. could damage the pump. the hotwire kit comes with a relay and gets it power from the alternator and wont damage the pump due to low voltage
Old Feb 2, 2016 | 09:36 PM
When installing the hotwire kit, is it all plug and play too?
Old Feb 3, 2016 | 03:29 AM
HCI2000SS's Avatar
Yes the hot wire kit is basically a plug and play. Very easy to do
Old Feb 3, 2016 | 08:08 AM
Perfect. That's what I like to hear! Lol
Old Feb 4, 2016 | 01:25 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
RFPK-001 = FPA-001B + FPWK017W - 99-02 F-BODY
http://www.racetronix.biz/customkiti...c=RFPK-001&eq=
FPA-002A - Fuel Pump Assembly (no harness) 98 F-BODY ONLY!
http://www.racetronix.biz/itemdesc.a...A-002A&eq=&Tp=
Given the age of these cars and the power requirements of the HP pumps the harness SHOULD be installed.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
