Installed Injectors Today ...
I re-installed the fuel pump fuse and re-connected the negative lead on the battery .... turn the switch on for 5 seconds ... did this several times and cranked it up. Then, I checked it for leaks and went for a test drive.
Above 4000 rpm's, it felt crisp and clean. The surging at high rpm's went away completely and restrictive feeling went away, as well. I bought the Texas Speed $60.00 injectors/rail set. The receipt says they are Bosch injectors.
Anyway, I don't know if the injectors netted me anymore max RWHP or RWTQ, however, I like the feel of the car now at high rpm's. If I replace the NGK TR-6's with the new NGK TR-55 plugs, will this help my car or hurt it?
__________________
Jeff
Not knowing much about tuning, this is just my personal view. If you're swapping both, I would re-tune if I could get it done at a reasonable price. I think the PCM probably adapts to minor changes where A/F is concerned, but, like I say, you'd really have to ask a tuner. You might want to defer this question to TimZ28. Just PM him and he'll be happy to advise, I'm sure. He is a tuner who would tell you the importance of having your car tuned and he can also tell of any negative effects of not having it tuned with these changes.
drift for a while as it learns the new injectors' flow
effect back out. In general you should see a 9%
enrichment effect. That means if you had any
positive trims and any lean problems at WOT, it
might get better. And certainly if you had any
injector balance issues (the stockers now being 5
years' worth of crusty) the new virgins will party
better. But once things are bedded in you may be
a bit fatter at WOT than ideal. Wait and see,
after the new mod euphoria wears off
We've done mail order tunes for several of the guys getting injectors for their 99-00 cars. The A/F will definately be a bit on the rich side. Haven't some of the guys gutted their maf to offset the bigger injectors? Does that really work?
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
If I hand port my throttle body, will it lean out the A/F richness caused by the new injectors at WOT? It feels great, however, I can smell the richness at all rpm ranges ... or, at least that's what it smells like to me.
