fueling issue? or something else?
Recently installed rebuilt LS2 engine with factory LS6 intake manifold so the fueling didn't change, also installed some wideband sensors and sure enough the car is still leaning out under WOT. I just installed new racetronix pump and now fueling issue is even worse, during this time I also ran a fuel pressure gauge and it only dropped 2-3 PSI under WOT... a little frustrated so I spent the big bux and bought new A/C delco unit and got that installed and still same issue. AFR under WOT is going to 20:1 or worse. I pay for remote tuning service and he's certain its a fueling issue and we've even tried a SD tune with the same results. I'll list things below that I've done to try to fix issue.
Checked fuel lines for kinks, was unable to check about 1' of line above fuel tank.
New A/C delco pump assembly
New Fuel filter
Fuel pump receiving 14.4V while car is on
Pressure is 57-60 PSI, I think it may have even been slightly higher with the racetronix pump
replaced MAF, Also ran SD tune with same issue
I'm $470 into this issue with a car that I can't floor... Any Ideas? do I just need to change out all fuel lines and fuel rail?
If the plastic lines seem okay, it may be time to start blowing an air compressor through the metal lines under the car to check for restriction. Obviously, take everything off the ends so that it is just a straight shot through.
Good idea on blowing compressed air through the lines, I'll try that.
If I am understanding that correctly, I don't think it is a fuel supply issue.
This morning I was thinking about my MAP sensor and i'm thinking maybe there could be an issue with that? I feel it'd have to be pretty far off to cause this much of an issue though. I can post up some of my log files if that would help.
I appreciate your responses eb110americana.
I picked up a fuel gauge pod and waiting for the adapter so i can keep a better eye on the pressures.
If the problem does not change, you can rule out the MAP. If it runs much better, then you have a faulty MAP or possibly faulty MAP tune.
Otherwise, yes, realtime fuel pressure with your new gauge will hopefully shed some light on the issue. Are you sure you have the right injectors for the tune his giving you?
I did have realtime fuel pressure reading when I had the gauge taped to the window lol. but a digital one will be easier to read.
Yes I'm sure the injector data is right, I put in that information before the tuner. Also I was having the issue before the injectors.
I've installed a fuel pressure sensor and gauge into my gauge pod so I can keep a closer eye on what the fuel pressure is doing, but here's the strange part. The car has good AFR's under WOT when cold. I did a couple WOT pulls a couple of minutes in to the being and it AFR was right about 11.5 and then another pull was even 11 and 10.9. As the car warmed up though I was getting leaner and leaner AFRs until WOT would be as high at 16:1. Also note the fuel pressure was behaving exactly the same at cold as it was at hot. So now I need to figure out what is causing this.... If interested I've attached my log file that shows good afr at start then leans out towards the end.
https://drive.google.com/open?id=0B2...kzRXkwRDVRUTlZ
