Corvette regulator on camaro
Thanks in advance.
After that filter you have pictured on the left is a large T and you can see just part of it there. The stock plastic line should go on the center feed of the new filter.
Then you will have to adapt the threaded stock outlet to the new filter (can't help as I used a Canton).
Your old return will have to be plugged. I used those GM to -an adapters like the blue ones shown and then put a -6an cap on it. The hard line goes to plastic near the axle and can be capped there. (Earl's makes those adapters where they thread on and don't rely on those plastic clips, use that style and skip the ones with clips)
You can then run a new return from the new filter to the old plastic return line that is loose at that point.
Get the Earl's or other adapters that thread closed only.
