octane & duration ?
Old Jan 13, 2018 | 03:02 AM
ls1 trex's Avatar
Default octane & duration ?
hi guys
i want to know about duration
is it true ?
low duration means needs more octane
high duration means needs low octane
Old Jan 13, 2018 | 07:57 AM
HCI2000SS's Avatar
Duration of what?
Old Jan 13, 2018 | 08:23 AM
ls1 trex's Avatar
for camshaft
Old Jan 13, 2018 | 08:28 AM
HCI2000SS's Avatar
Not with the cams that we run for our cars
Old Jan 13, 2018 | 09:05 AM
ls1 trex's Avatar
like this simple
is it that cam shaft
225/236 .629"/.615"
need more octane than
235/248 .649"/.615"
Old Jan 13, 2018 | 09:09 AM
HCI2000SS's Avatar
Nope it's not going to make hardly any difference all on its own
Old Jan 14, 2018 | 10:12 AM
.boB's Avatar
Originally Posted by ls1 trex
hi guys
is it true ?
Sort of. More duration means the intake valve is open longer, and usually means it closes later in the cycle. That means it will increase dynamic compression and cylinder pressure. That's kinda the point, because that's how you make power. To prevent detonation, you would want to use a higher octane fuel.
But as said above, the example you've given in an otherwise stock engine probably won't be a big enough change to matter all by itself.
Old Jan 14, 2018 | 12:05 PM
pantera_efi's Avatar
Default Cylinder Pressure = BMEP
Hi Trex, I agree with your observation due to changes in cylinder pressure as stated above.
The engine will compress the Air/Fuel AND HEAT this mixture from compression energy input.
The hotter the mixture, the more octane is required to prevent Pre-Ignition.
UNDERSTAND this effect is RPM related.
Lance
Old Jan 14, 2018 | 12:17 PM
Crf450r420's Avatar
Look up dynamic compression and that will help show you see how that is correct. The closer the intake closes to BDC the move volume that is compressed in the cylinder and the more that will heat up when compressed.
Old Jan 14, 2018 | 11:26 PM
ls1 trex's Avatar
thanks guys ,,
Old Jan 20, 2020 | 09:54 PM
qwiketz's Avatar
any updates on this one? I just paid about $12.xx a gallon for sunoco 260 plus... Wondering if this is really pricey or basically the norm these days.
