Inline pump, pro and cons
Hey guys!
Additonally with my h/c/i swap i'll be thinking about a fuel pump upgrade, car is '05 CTS-V with saddle tank and i'm hopin on 450rwhp with 42lbs injectors!
For less stress and not heavin the time to drop the tank to build in Walbro or Racetronix, i will try this way maybe...
I will build in bigger feet or return line and a fuel regulator, so i have the same results with a Bosch 044 like i go the in tank way, where is the different or the loss here?
Thanks in advance...
Greetz
Ron
Greetz
Ron
I do alot of ls swaps in the older cars and trucks. 90% of the time i use a inline pump. Makes it way easier when a vehicle originally had a carb on it. On yours if u want to run a inline pump, thin plumb it up and have at it. Works either way.
But if it were me, i would install an intank pump. Easier to just remove the original pump and replace with new one. Alot of headache, money, etc. Saved!
Hi Ron, MOST performance cars built by OEM's use Dual Pumps.
The first pump is in/near the tank AND the second pump is "mid" car, an inline pump.
YES, use a return 1/4" line back to the tank from the rail regulator output.
I manufacture Fuel Pumps, inline billet case.
My site is PanteraEFI.com, "see" new products, fuel pumps.
Lance
Lance
Ok, thanks for positive post going that way, it encourages me doing that...
So i can use the installed oem line in 3/8" with 8mm inner diam to feed the engine and return maybe 4AN with 6mm inner?
Greetz
Ron
Greetz
Ron
