what brand injector for 1600-2000cc
Old Feb 22, 2018 | 08:50 PM
shesacummins's Avatar
Default what brand injector for 1600-2000cc
Im building a turbo ls3 with the goal of around 1k hp on Flex E85. i cannot afford to drop 2k on ID's. ive been trying to find info or feedback on bosch and holley injectors, not set on any brand. im trying to get the best bang for my buck without going poor.
thanks
Old Feb 23, 2018 | 12:56 PM
Jakewet28's Avatar
Why do you need such a big injector? At 1300 to the crank (over-estimation, I know) with an 85% duty cycle on an e85 turbo application, you'll need a 1300cc injector at 3 bar rail pressure (which is what most of these injectors are rated at). I plan on hitting 1000 to the wheels on E eventually and just picked up a set of 1300cc FID injectors from a vendor on the GTO forums and it only cost me $750.
Old Feb 23, 2018 | 03:09 PM
from what all the injector calculators are saying is that they recommend 1300cc for E at 80% so im basing it off that. not 100% sure, but i rather go too big, over too small. thats a good deal! can you send me a link to where you got them? thanks for the input
Old Feb 23, 2018 | 03:37 PM
Jakewet28's Avatar
I think you may be seeing a lot of high recommendations because all of the usual injectors from companies like ID or Deatschwerks use a base pressure of 43.5. If you use an injector that states that it is 1300 cc at 43.5 psi of rail pressure at 58 psi rail pressure, it becomes 1500cc instead. I use the calculators on Deatschwerks website and its telling me that for a turbo application for your car with 1000 hp to the wheels (1176 at the flywheel with a manual transmission right about) on e85 with an 80% DC, you'll need 1254cc injectors. This is with a 43.5 psi base pressure though, which all of the injectors on their site (and ID's site) are default rated at so at your pressure (58 psi), they're actually 1448cc injectors. And I'll shoot you a PM about where to get them.
Old Feb 24, 2018 | 07:46 PM
stevieturbo's Avatar
Around the 1600cc mark it seems everyone just sells/resells the Bosch CNG injector 0280158333 with various top hats to suit different applications. ( Or there is another seemingly identical ending with 4 instead of 3 )
And with widely varying prices.
Some rate these as low as 1450cc, others as high as 1700cc....even quoting same pressures.
Bosch's own listing for these ( Aus site )
https://www.bosch-motorsport-shop.co...-ev14-injector
What would be worth paying a little extra for is ensuring you get a set that have been either flow matched, or have flow data supplied so you can trim individual cylinders ( assuming you use an ecu that allows this )
If you search for that part number you get a plethora of sellers and options. These are just some ( as I've been looking recently myself )
http://www.finjector.com/verkkokaupp...lts/0280158333
https://fuelinjectorconnection.com/c...njector-for-ls
https://www.ebay.co.uk/itm/8-Genuine...item48a66d53d5
Old Feb 25, 2018 | 11:42 AM
pantera_efi's Avatar
Default Bosch/Ford Alt Fuel S/S injectors
Hi ALL, I sell the Ford fitted Bosch Stainless Steel (internal S/S) fuel injector intended for "E" fuels, they are of the size you request AND I too have fitted this injector on LS-x engines with "E" fuels.
I sell this injector to LS-1 Tech members for $105.00, a discount over retail.
Lance
Old Feb 25, 2018 | 11:29 PM
Oh hell yeah! I appreciate all the good info. Definitely wanting to get a matched set
Old Feb 26, 2018 | 06:52 AM
JoeNova's Avatar
Restricted User
If you want a guaranteed set that will work with E85, go with the ones Lance is offering to sell you for $840/set.
Your next best option are the Bosch 210s. They're huge injectors and they are stainless (although a few have reported issues with them with E85). They are the base injector that all of the aftermarket injector companies use for their 2000cc injectors.
The Bosch 160s don't work very well in street cars.
Old Feb 26, 2018 | 01:48 PM
But which "Bosch 160"....there seem to be many variants of all the injectors.
Old Mar 1, 2018 | 09:12 AM
Apsuzak's Avatar
can you send me this as well? Looking for a set for an LS3
Old Mar 1, 2018 | 12:07 PM
Jakewet28's Avatar
You have a PM sir.
Old Mar 2, 2018 | 09:32 AM
Default Injector OHMs
Hi All, I may have a report of Value.
There are Large Flow injectors that ARE LOW OHM.
The GM-LS PCM uses an injector driver IC that can ONLY drive High Impedance fuel injectors.
The IC also has Fault Protection with reports to OBD Flash when current flow of an injector is TOO GREAT.
Thus the need to ask the resistance value of a fuel injector when matched to a GM PCM.
Lance
Old Aug 28, 2018 | 11:26 AM
AUS Injection's Avatar
For all of your fuel injector needs or questions give us a call send me an email Justin@AusInjection.com
