fuel pressure drop after warmed up.
Old 03-12-2018, 02:46 PM
customblackbird's Avatar
at 450rwhp you making 550hp at the engine which i'm using a 20% drivetrain loss. You wont have much pump above that. The reason its holding up fine is the Deka 80lb at 43psi so at 58psi they flow 90+lb. So that this point your only limited by the pump flow at said pressure. If I were you I would drop fuel pressure to 43psi and input the 80lb as the flow rate as you wouldnt be getting close to maxing those 80lb at 43psi even at 650hp or 500rwhp.
Not sure who told you about that but plenty of guys run the 340s and 380s or even the 450s I think with the stock truck rails.
Old 03-12-2018, 07:16 PM
Swapper's Avatar
so i wrapped some heat reflective tape around my fuel lines where it gets close to the exhaust, made sure there wasnt any kinks in the line. removed the ground and relocated it onto a different spot on the frame. (cleaned and bolted to frame). removed the gas cap. think im going to lift the bed up, check the filter and most likely do the re-wire and maybe order a pump
So that's after its warmed up and starts running low pressure.
That's after turning the key off for 2 seconds and turning it back on.
Old 03-12-2018, 07:29 PM
It’s running a intank 255? I would be checking fuel sock on the pump. What is the fuel level during these tests? Hard to say but can you check pump amp draw when it’s loud vs when it’s not?
Old 03-12-2018, 08:40 PM
Swapper's Avatar
yeah its a in tank. i got a half tank of gas right now. i dont think i can get to the wiring without lifting the bed. if i have the bed lifted i dont think ill be able to make it get to where its noisy. those videos were after like a 5-10 minute drive. 2 pulls in boost. then noticed it started running lean while cruisin so just rolled home.
Old 03-12-2018, 09:21 PM
LLLosingit's Avatar
As far fetched as it might be there is another possibility to could explain how shutting it off for couple seconds would make it run fine for a short time. I wonder trash is getting sucked against the pump pick-up then it falls away when it's shut off for a second them picked back up again. Not likely but is possible, Something to keep in mind if you pull the pump.
Old 03-12-2018, 09:46 PM
Crf450r420's Avatar
If it's not vac issue then it almost has to be trash that is clogging and falling off when it's shut down. It can't be heat as that wouldn't cool off that quick.
Old 03-12-2018, 10:47 PM
Swapper's Avatar
thats what my buddy said. if it its i gotta figure out how to get it out without having to suck out all the gas.im at just under 1/2 tank now so i guess ill just burn through it and go from there.
Old 03-13-2018, 09:25 AM
Disconnect the pressure line at the engine and turn the pump on to push all the fuel out of the tank. Shouldn't take more than a few min. Just pump it into a couple of gas cans.
Old 03-13-2018, 07:15 PM
Swapper's Avatar
so today i replaced the fuel filter. was only on for just over 100 miles. fuel was dark brown and sandy looking. havent got to test drive it yet to see if it helped any. was looking on rock auto tho and noticed i can get a new tank for $67 shipped. which is cheaper/ about the same as local companies charge to clean a tank. so im most likely just goin to order that and a new aeromotive 340 pump and most likely a wiring kit if i can find one thatll work. hopefully thatll fix everything. and again thanx everyone for the help. i will update with results.
Old 03-15-2018, 08:11 PM
Swapper's Avatar
test drove it and same issue. so ordered a new tank and aeromotive 340 pump. waiting on racetronix for their response on what kit might work, if not ill just wire mine own in.
Old 03-16-2018, 11:27 AM
Crf450r420's Avatar
Sounds like you should have fixed here soon. Filter is so cheap it's always a good place to start looking.
Old 03-18-2018, 01:32 PM
  #32
Swapper's Avatar
so dropped the tank and found um well yeah. pretty sure thats my problem. got the pump already. tank should be here tomorrow and probably going to replace the fuel filter again just cause. hopefully thats it and im good to go back to the tuner. maybe crank up the boost a little more.
Old 03-18-2018, 02:10 PM
  #33
Looks about right. The new 340 pump and a new tank should give you more wiggle room and boost capability. All good upgrades.
Old 03-18-2018, 08:44 PM
  #34
LLLosingit's Avatar
I can see where that might explain why the pump would act like that, Holy crap...I don't think I've ever saw a mess like that unless the tank was rusty.
There may not be anything wrong with the pump other than the screen getting plugged, Definitely explains why turning it off for a few seconds let it run again.
Any idea what the its from?
Old 03-18-2018, 09:36 PM
  #35
Swapper's Avatar
the truck sat for 10 years before i bought it. it used to have a lt1. when i got the truck i pulled the tank and tried the home tank cleaning products. tried muriatic acid. letting it sit, shake with stuff in it a couple of times but i guess i didnt get all of it. at the time i filled it with water to see how clean it was and it was then. im guessing running new gas through it lately took off more stuff from the walls inside. it ran fine with the lt1 for a couple months but guess the fuel pressure demands of the turbo 5.3l is a bit more than the lt1's.
im just glad i figured it out.
Old 03-24-2018, 12:10 PM
  #36
Swapper's Avatar
so it looks like that was the issue. rain finally cleared up enough that i got to drive it a bit. ran fine got into boost multiple times with no issues. also this aeromotive pump is alot quieter then the walbro was. when i first went to prime it after installing everything i thought it was a dud cause i couldnt hear it.
